KillerBob
Jun 06, 2016Aspirant
LACP and Jumbo Frames
I am running my Pioneer Pro setup using LACP from my NAS to an HP 2915-8G switch. I connect to the switch using LACP to my Mac Pro, and normal ethernet to my Mac Mini. My Ultra2 also connects using L...
Jun 07, 2016Guru - Experienced User
When you disable LACP are you also removing the second ethernet cable?
Also, sometimes LACP's MTU is configured separately from the normal ethernet MTU in the switch. I don't know if HP does that, but Netgear switches do.
