KillerBob
Jun 06, 2016Aspirant
LACP and Jumbo Frames
I am running my Pioneer Pro setup using LACP from my NAS to an HP 2915-8G switch. I connect to the switch using LACP to my Mac Pro, and normal ethernet to my Mac Mini. My Ultra2 also connects using L...
Jun 07, 2016Guru - Experienced User
When you disable LACP are you also removing the second ethernet cable?
Also, sometimes LACP's MTU is configured separately from the normal ethernet MTU in the switch. I don't know if HP does that, but Netgear switches do.
KillerBob
Jun 07, 2016Aspirant
I am not disabling LACP, I am "only" turning on Jumbo Frames, ie. setting the MTU to 9000. On the NASes, and on the Mac Pro and the Mac Mini. As soon as I so this, I can still access the shares, nut I cannot get into FrontView...
- StephenBJun 07, 2016Guru - Experienced User
Got it
Are you seeing errors in the ProCurve logs?
I had a similar problem once, and the issue was that the max frame size for LACP wasn't inherited from the max frame size for the switch ports - it needed to be set separately. It might even be possible that ProCurve doesn't support JF with LACP.
- KillerBobJun 07, 2016Aspirant
You are right:) In the logs on the 2915 it reads "Excessive undersized/% giant packets". The switch does support Jumbo Frames, but I don't see anywhere I can enable it - I have always used the webinterface. I guess that's what the problem is...
- AnonymousJun 07, 2016
I know this won't help to solve the actual issue, but honestly, Jumbo Frames is not going to bring any significant performance increase, even on an x86 box, it's just not worth the effort.
They are enabled on my switch, but I keep them off on my equipment unless I am testing.
When there is gain, it is related to CPU load, not the network itself. Larger packets means less frequent packet interupts and related processing, and that can sometimes improve performance. The faster the system, the less gain there is.
JF are a nuisance when you have equipment with different MTU ceilings - resulting often in fragmented packets that are either dropped, or which slow down performance.
That said, they should work in this case unless there is a restriction in the switch.
StephenB wrote:they should work in this case unless there is a restriction in the switch.
It should work, that's true. Worth the effort, I'm not sure of that ;)
