KillerBob
Jun 06, 2016Aspirant
LACP and Jumbo Frames
I am running my Pioneer Pro setup using LACP from my NAS to an HP 2915-8G switch. I connect to the switch using LACP to my Mac Pro, and normal ethernet to my Mac Mini. My Ultra2 also connects using L...
KillerBob
Jun 07, 2016Aspirant
I am not disabling LACP, I am "only" turning on Jumbo Frames, ie. setting the MTU to 9000. On the NASes, and on the Mac Pro and the Mac Mini. As soon as I so this, I can still access the shares, nut I cannot get into FrontView...
Jun 07, 2016Guru - Experienced User
Got it
Are you seeing errors in the ProCurve logs?
I had a similar problem once, and the issue was that the max frame size for LACP wasn't inherited from the max frame size for the switch ports - it needed to be set separately. It might even be possible that ProCurve doesn't support JF with LACP.
- KillerBobJun 07, 2016Aspirant
You are right:) In the logs on the 2915 it reads "Excessive undersized/% giant packets". The switch does support Jumbo Frames, but I don't see anywhere I can enable it - I have always used the webinterface. I guess that's what the problem is...
