ozstockman
Jan 25, 2022Aspirant
LEDs are blinking at constant rapid speed without any code indication
Hi guys, I am looking for some solution as search does not show anything like I am experiencing. I have this NAS setup and running for years. Never had any problems with it apart from yesterday. T...
Jan 26, 2022Guru - Experienced User
ozstockman wrote:
I tried to factory reset without my HDDs
It can't be done. The factory install formats the hard drives, and does a fresh factory install onto the disks.
ozstockman wrote:
in the morning I found my NAS not functioning and here is what it is doing. There are no LED On for any of two drives(I am using WD red) installed. If I leave the HDDs in bays and connected I got Act(I believe means active) LED On and solid(not blinking) and I have power LED and Backup LED blinking rapidly at the same speed non stop. I cannot turn my NAS off apart from unplugging a power cord.
Try removing power. Then remove the hard drives (labeling them by slot).
Power up the NAS w/o the drives, and install RAIDar on a PC. See if it finds the NAS and reports a "no disks" status. https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
- ozstockmanJan 26, 2022Aspirant
Thanks for a suggestion. I have tried it already and it cannot be found even when the system is plugged directly to a laptop with an ethernet cable. The ethernet LED at the back seems to show its active status but the nas not resposding to pings. Its IP is set to be fixed so I do not beleive even that part is working.
I have tried to keep it unpowered for the whole night. In the morning when I plug it it is doing the same with LEDs.
I have also tried otherwise(left it powered for hours) hopping it may just trying booting up. Nope, not a fix.- ozstockmanJan 26, 2022Aspirant
There is a bit of change in LED statuses so I guess I'll need to let others know in order to find a fix.
After leaving the system for another 5 hours unpowered and powering it again it now has only one power LED flashing at a slower speed than before. So the frequency of flashing is different from before.
Backup LED is now OFF all the time which is different from a previous state. With all previous attempts it was ON straight after powering and usually started flashing at the same speed as a power one with a delay of 1-2 once powered.
With no disks in the bays Act LED is OFF but once I install at least one disk Act LED turns ON with solid light(not flashing). The same as before.Also a much bigger change is the system now can be found on LAN with Raidar. However it shows a wrong IP address(192.1.168.168) which seems to be not coming from any DHCP. The fixed IP that was setup in the system should be 192.168.1.7
192.168.168.168 is not responding to pings. Raidar can see system details such as firmware, serial number etc but always says it is diskless no matter if the HDDs are in their bays or not.
- StephenBJan 27, 2022Guru - Experienced User
ozstockman wrote:
Also a much bigger change is the system now can be found on LAN with Raidar. Raidar can see system details such as firmware, serial number etc but always says it is diskless no matter if the HDDs are in their bays or not.
Do you have a spare disk you can test with? (removing the real disks, and inserting just the spare in the NAS). Best to label the disks by slot as you remove them.
One possibility is that the SATA hardware in the NAS has failed. That isn't repairable. But it is also possible that a failed disk is bringing down the SATA bus.
