notcounting
Mar 19, 2014Aspirant
Limit On Volume Count?
I have a readynas Ultra 6 unit that I am using in flex-raid mode. I added a new disk to the unit, and it recognized the disk as OK. The problem is that it is not letting me add a new volume for the...
mdgm-ntgr
Mar 21, 2014NETGEAR Employee Retired
OS4 had the volume names c d e and f hard coded into the OS, so adding support for 6 volumes would require manually adding some lines of code. With OS6 you name your own volumes and it is written in such a way to allow more volumes than you are likely to need.
With OS4.2.x there is the disk test boot option, just like there is on OS6.
OS4 runs a short online SMART test daily at 4am. You can do offline SMART tests manually if you really want to (it's just not something that's likely to be explained here).
