michaely1
Jul 20, 2011Aspirant
Lion & Time Machine - NV+
Will there be an update to the NV+ to support Lion, especially around Time Machine. I've picked up the AFP fixed add-on, that's all working on the filesystem, but I have no backup at all now. If yo...
ChrisMc73
mdgm wrote: The update would include an update to Netatalk 2.2 (project that provides AFP and Time Machine to the ReadyNAS). It may include some other updates as well.
To access shares via AFP you have to have AFP enabled for the share under Shares > Share Listing > Sharename > AFP. If AFP wasn't enabled you wouldn't have been able to access the share over AFP.
When you setup Time Machine, AFP is automatically enabled if it wasn't already.
Well I'm pretty sure I had CIFS/AFP/NFS enabled for both my shares. In fact, unless Lion changed it, thats what shows in Frontview now, all 3 of those are enabled.
Anyway, regardless, its working now. Any reason you know of why CIFS isn't working now? Will that be fixed in this update? Thanks for your info and help.
