michaely1
Jul 20, 2011Aspirant
Lion & Time Machine - NV+
Will there be an update to the NV+ to support Lion, especially around Time Machine. I've picked up the AFP fixed add-on, that's all working on the filesystem, but I have no backup at all now.
If you haven't upgrade to Lion and wants to keep TM working, DON'T UPGRADE!!!!
thanks
Mike
thanks
Mike
- ChrisMc73AspirantSo what exactly is the deal with the AFP issue and Time Machine, why its not working?
How long till they fix this do you think? - mdgm-ntgrNETGEAR Employee RetiredTime Machine on Lion requires Server Reply Cache. This is not present in the version of Netatalk included in 4.1.7. The fix should be seen as an urgent issue now so they will work to release a fix as quickly as can be done reasonably.
- sqsuicaAspirantI wish I have read this before and luckily I didn't do clean install.otherwise I will have nothing at all now. It will be great if there is a trade in upgrade to a intel model readynas!!!
- ajp8164AspirantHi All,
Just want to +1 (+100) for correcting TM/Lion issues with NV+!
I upgraded yesterday without researching against RN. So, no backups for now. I have two Macs that rely on the NV+ for TM backup (only one Mac is Lion). Everything else seems to be working very well.
Any ETA on a fix for the NV+? (I read Yoh-dah's post re: support and the coding optimization need).
Also, Thanks for a great device that just works! Reliable and easy to use!
-Andy - yoh-dahGuideThere's a RAIDiator 4.1.8-T5 beta out that should fix Lion incompatibility - viewtopic.php?f=17&t=55155
- richardh1AspirantHmm. Installed 4.1.8-T5 and then on login over AFP, got the "Something wrong with the volume's CNID DB... ...switching to read-only mode." message, which I think is a Netatalk error. Result is that one of my shares (my 1TB or so of my photography) is visible but shows no files within it (via Finder). However, if I go in via ssh, everything is present so clearly an AFP issue.
ATM, this is an irritant - content is backed up so not panicking. Give me a couple of days though and I might start.
Question: I discover (after the horse has bolted) that this issue has been known about for at least 8 months - so how come it's taken so long for there to be even a beta fix?
Richard - mdgm-ntgrNETGEAR Employee RetiredNetGear is one of the customers of NetAFP. Take a look at http://www.netafp.com/customers/ and http://www.netafp.com/status-of-netatalk-and-afp-support-by-nas-vendor-322/
NetAFP has been working on the fix for several months (at least) and if the Lion Dev Previews changed how things work adapting to those changes.
NetGear does not support beta OSes so saw no need to release an update till after Lion was officially released to the public (why add a fix for something only to find the fix doesn't work with the production OS?). Of course as the NetAFP team has been updating the Netatalk project over time and NetGear obviously doesn't want to add an old unstable release of Netatalk 2.2 to Sparc firmware, the latest release would present new challenges for backporting compared to the earlier Netatalk 2.2 releases which would explain the additional development time needed to get an update ready for Sparc. - ajp8164Aspirant
richardh wrote: Hmm. Installed 4.1.8-T5 and then on login over AFP, got the "Something wrong with the volume's CNID DB... ...switching to read-only mode." message, which I think is a Netatalk error. Result is that one of my shares (my 1TB or so of my photography) is visible but shows no files within it (via Finder). However, if I go in via ssh, everything is present so clearly an AFP issue.
Richard
I think I'll wait a bit. I have 3+TB of original photography without a backup (other than RAID protection).
Thanks for working on this fix! :D Looking forward to a stable release soon :wink:
-Andy - ajp8164AspirantAny feedback on this from anyone else. Is this beta working okay for folks or are there issues?
-Andy - richardh1AspirantInstalled the Beta and my Macs then took ages to see any folder content. They finally caught up and now all seems fine.
