viperhansa
Apr 03, 2014Virtuoso
Loadavg addon.
Hi guys.. Seems like my installation of the add-on Loadavg cant find any logfiles. Can anyone point me in a direction where they are hiding? 8)
fastfwd
If that's Super-Poussin's addon, it's very old and might not run on new systems at all. If you are comfortable with Linux, you might want to download and install the latest version of LoadAvg instead, from http://www.loadavg.com/.
Note that LoadAvg, whether old or new, requires PHP to be installed first. If you haven't already installed a PHP addon, you should uninstall the loadavg addon and then install the WhoCares? PHP addon (it is much newer than Super-Poussin's PHP addon) and reinstall loadavg. If you have already installed Super-Poussin's PHP addon, you must not install the WhoCares? addon over it.
And to answer your question... As far as I know, the LoadAvg program gets its data from /proc/loadavg .
