Chlorate
Jan 28, 2013Aspirant
Locked files issue
Hi, I have a ReadyNas 2100 with RAIDiator 4.2.22. Before finding out about this forum, I performed the apt-get update && apt-get upgrade with the default sources.list. It apparently upgraded login, ...
chirpa
Feb 02, 2013Luminary
Yes, though there is a method to reset the OS partition without moving data (risky). There are forum posts on that topic.
OS Re-install should restore most of the programs, I'd try that method first. http://www.readynas.com/kb/faq/boot/how ... _boot_menu
I'd also be curious if downgrading to 4.2.19 firmware makes a difference.
