Chlorate
Jan 28, 2013Aspirant
Locked files issue
Hi, I have a ReadyNas 2100 with RAIDiator 4.2.22. Before finding out about this forum, I performed the apt-get update && apt-get upgrade with the default sources.list. It apparently upgraded login, ...
Chlorate
Feb 11, 2013Aspirant
Solved it !
No more Locked File issue.
In a Windows Explorer window, do the following:
1. Right click on the Start Button.
2. Click 'Open Windows Explorer'.
3. At the top left click Organize > Layout
4. Uncheck Details Pane and Preview Pane.
5. In Control Panel > Folder Options. Click on the View tab. Scroll down the list to “Show pop-up description for folder and desktop items” and clear the checkbox and then click OK.
