Chlorate
Jan 28, 2013Aspirant
Locked files issue
Hi, I have a ReadyNas 2100 with RAIDiator 4.2.22. Before finding out about this forum, I performed the apt-get update && apt-get upgrade with the default sources.list. It apparently upgraded login, ...
rapple
Oct 01, 2013Aspirant
David,
did you get anything from anywhere to fix this in the end? I am only using in a home office context but I am experiencing the issues almost constantly. Same set up as you NAS version and for the main users the OS but I also have issues on an XP Pro machine.
To be honest I don't see it as acceptable in a home situation either. When almost every file that you put on there is locked, even one that you yourself just filed and then closed the application.
That means log in, reset and propagate permissions etc. every time for me, the wife and the kids. Nope.
