CMoney408
Jan 08, 2015Aspirant
log into readynas interface remotely WAN and more questions
Hello, NAS: Ready Nas 314 OS 6.2 first i would like to let everyone know i am very new to using a NAS. so all tips are appreciate, though tips with detailed (baby) steps are always preferred (as...
Jan 08, 2015Guru - Experienced User
BTW, you can also use a different port. There is a "port 2" field you enter on the NAS HTTPS settings, and then forward that port value. Anything over 50000 is a good choice. Then use https://WAN_IP_Address:xxxxx/admin as the url (xxxxx being the port number you pick).
Some routers won't let you forward 443, since they reserve it for their own remote administration. And some ISPs block it.
