sp3107
Feb 07, 2017Aspirant
Loosing connection to Readynas 312
Have a network with 7 computers running windows 7 through a netgear pro switch. Keeps loosing access to the Readynas, says unable to connect. I can access other computers with no problem.
JennC
Feb 08, 2017NETGEAR Employee Retired
Hello sp3107,
I suggest to check the cable connection first between the switch and ReadyNAS, make sure the cable is plugged in securely. If you can try another port on the switch, please do. I believe the RN312 has 2 LAN ports, if have both plugged in, unplug one of them.
Please also provide the current firmware version.
Welcome to the community!
sp3107
Feb 08, 2017Aspirant
Yes, that is the first thing i did, i replaced both cables that I know worked. I also changed the network switch. The NAS is running 6.6.1
