iamthemitch's avatar
Oct 24, 2016
Loses network connection on Ultra 2 when router is unplugged / restarted
Hi,
I'm running my Ultra 2 for years now, and updated it to OS6 for a while too.
All is running smoothly, but sometimes I have a weird network issue.
When I have to unplug or restart my router, the Readynas isn't able to get back network connectivity, and I need to restart it too.
That's quite annoying, and I never investigate much on it.
Did I missed a setting somewhere ?
Is there any specific Netgear network service to restart / reload ? might be done with Monit.
Thanks!
    • mdgm-ntgr's avatar
      mdgm-ntgr
      NETGEAR Employee Retired
      Perhaps download the logs and look for clues in those.
      Is your NAS connected to gigabit router/switch or just a 100 megabit one?
      • iamthemitch's avatar
        iamthemitch
        Star
        Well, didn't find any relevant information in the logs for now.
        Do you have a specific one in mind ? will reproduce later on.
        Even try a ping test via crontab with ifconfig eth0 down / up if failing, but doesn't seems to restore the network layer.
        I'm using a TPLink Archer C5 (1Gbp) as router, and don't have any issues with desktop on Xubuntu.
ProSupport for Business
