Gear
May 05, 2016Guide
losing connection
Recently upgraded OS to 6.4.2. Now I'm having problem with connecting to the NAS. If I do a power reset I will be able to connect to a share (SMB) but pretty soom it will be lost. Same goes with t...
JennC
May 05, 2016NETGEAR Employee Retired
Hello Gear,
When you lose connection to the NAS, does the NAS still show on RAIDar? It is possible that it is losing the network connection.
Try backing up the file to a USB disk that is plugged in to the NAS directly, in that way, the backup job would not need to go through the network.
