Gear
May 05, 2016Guide
losing connection
Recently upgraded OS to 6.4.2. Now I'm having problem with connecting to the NAS. If I do a power reset I will be able to connect to a share (SMB) but pretty soom it will be lost. Same goes with t...
Gear
May 06, 2016Guide
Thanks for the tips.
I manage to enable ftp access and that seems to work better than SMB so its been downloading all night, and still working this morning.
Attaching the USB directly would probably be a faster option, but since it's working I will let it go through... lots of data.
mdgm-ntgr
May 06, 2016NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig)?
