Anders_Andersso
Mar 21, 2013Aspirant
Losing contact with my nv+
I have a ReadyNas NV+ that´s hooked up to my macbook pro 10.8.3 via my home wifi network. It has worked fine up to now, when my computer suddenly loses contact with the stuff on my readynas. I use it ...
Mar 21, 2013Guru - Experienced User
He will want the instructions here: http://www.readynas.com/kb/faq/boot/how ... _boot_menu Your hardware manual also has this information (sometlmes the hardware manual is more clear).
Also, the reinstall will reset your admin password back to the factory value (either password or netgear1, depending on what model NAS you have), and set the IP configuration to use DHCP.
Do you know if you have a v1 or v2? There is a guide here: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
For the nv+, the v1 products are silver, the v2 are dark gray.
