Anders_Andersso
Mar 21, 2013Aspirant
Losing contact with my nv+
I have a ReadyNas NV+ that´s hooked up to my macbook pro 10.8.3 via my home wifi network. It has worked fine up to now, when my computer suddenly loses contact with the stuff on my readynas. I use it ...
Mar 22, 2013Guru - Experienced User
Most loss of contact issues are caused by one of the following things:
Anders Andersson wrote: I just updated to 4.1.10, that might have something to do with things...
(a) A failing ethernet card in the NV+
(b) A failing disk
(c) A nearly-full OS partition.
I haven't seen any clear connection with 4.1.10, though there could be one I guess. You can easily downgrade back to 4.1.8.
You'd first download the 4.1.8 image from here: http://www.readynas.com/?p=5827
Then you install it via frontview. (system->update on the left menu, then select the "local" tab. Browse to the 4.1.8 binary, and click upload and verify image.
