pgovil
Jul 19, 2018Aspirant
Lost Volumes following stuck Reboot
My NAS was gracefully rebooted but it was stuck at 97% for a long time so I forced reboot it. Unfortunately my volume is now missing. I can SSH to the NAS and also from GUI I can get to it but I get ...
mdgm-ntgr
Jul 19, 2018NETGEAR Employee Retired
You could send your logs in (see the Sending Logs link in my sig).
- pgovilJul 20, 2018Aspirant
GM mdgm, thanks for your response. Is there a way I can tar/gzip or just extract the logs from shell and send you. My NetGear NAS web page is again stuck. I went to look at the front of the NAS and I see it's stuck again and in the process of rebooting again. I can SSH fine though and see the following mounted FS
root@ReadyNAS64:~# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 2.7G 4.0K 100% /
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 1.9G 8.7M 1.9G 1% /run
tmpfs 961M 1.4M 960M 1% /run/lock
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup- StephenBJul 20, 2018Guru - Experienced User
/dev/md0 4.0G 2.7G 4.0K 100% is a bit unusual, saying that you are using 2.7GB out of 4.0GB, but the volume is 100% full. You could balancing the OS partition (using the btrfs command from ssh).
Though 2.7G used is also quite full - you must have installed some packages or apps that use OS partition space. You should probably shift some of those folders to the data volume (symlinks are one way to accomplish this). Of course that will need to wait until the data volume is mounted.
Thank you StephenB for your time. Yes, I agree a FS at 100% is just not right. I am trying to think if I did any package update before that may have taken effect following the reboot but can't recall (likely I am forgetting, after all something changed). Since I have another NAS on network and have connectivity I can temporarily scp files over if that might help and then attempt to do a reboot again to see if NAS can be brought up online
My previous response to this message did not get sent. I am sending the message again. please change the extension of the attached file to zip as the same is not permitted for uploading.
I guess I still can't upload getting an error
Correct the highlighted errors and try again.
- The attachment's system_log-readynas64-20180720-114325.pdf content type (application/pdf) does not match its file extension and has been removed.
- pgovilJul 22, 2018Aspirant
mdgm, since the web portal is not accepting the log downloaded from NAS admin page and its getting truncated when I post the log for your review online, do you have a suggestion to send you the logs any other way? I have it; just can't upload to community page thread. Thanks for your time.
