pgovil
Jul 19, 2018Aspirant
Lost Volumes following stuck Reboot
My NAS was gracefully rebooted but it was stuck at 97% for a long time so I forced reboot it. Unfortunately my volume is now missing. I can SSH to the NAS and also from GUI I can get to it but I get ...
pgovil
Jul 20, 2018Aspirant
GM mdgm, thanks for your response. Is there a way I can tar/gzip or just extract the logs from shell and send you. My NetGear NAS web page is again stuck. I went to look at the front of the NAS and I see it's stuck again and in the process of rebooting again. I can SSH fine though and see the following mounted FS
root@ReadyNAS64:~# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 2.7G 4.0K 100% /
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 1.9G 8.7M 1.9G 1% /run
tmpfs 961M 1.4M 960M 1% /run/lock
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
Jul 20, 2018Guru - Experienced User
/dev/md0 4.0G 2.7G 4.0K 100% is a bit unusual, saying that you are using 2.7GB out of 4.0GB, but the volume is 100% full. You could balancing the OS partition (using the btrfs command from ssh).
Though 2.7G used is also quite full - you must have installed some packages or apps that use OS partition space. You should probably shift some of those folders to the data volume (symlinks are one way to accomplish this). Of course that will need to wait until the data volume is mounted.
