Retired_Member
Dec 16, 2015Low Performance creating and expireing backups with dirvish (rsync)
Hello, I've got a ReadyNAS RN102. I manually installed dirvish (http://www.dirvish.org/dirvish.8.html), a backup tool which uses rsync with hardlinks. With ReadyNAS OS 6.2.x, expiring old backup...
- Dec 18, 2015
Your data volume is extremely full.
I would suggest getting volume usage down to 80% then running a balance.
With defrag and balance scheduled weekly (run these at times when the NAS is being used lightly) you should find performance is better than what it was before for you.
mdgm-ntgr
Dec 20, 2015NETGEAR Employee Retired
Under System > Volumes you should see the progress of a balance.
You will get alerts in the status log (System > Logs) for when scheduled volume maintenance starts and when it finishes.
Retired_Member
Dec 24, 2015Thanks for all this information. Everything work good now.
Just one thing in addition:
There is a translation error in web logs.
English: Volume: Defragmentation started for volume DATEN.
German: Volume: Defragmentierung für Volume DATEN fehlgeschlagen. (translated: defragmentation FAILED for volume)
