geojay
Jan 15, 2020Guide
Lowest risk way to swap a drive in RN214
I currently have two 4TB drives in my NAS and would like to swap one of the drives for a new drive. What's the lowest risk way to achieve this? If I remove one of the two existing drives and replace ...
- Jan 15, 2020
Back up the data before you do it. You should have a backup plan anyway, as RAID just isn't enough to keep your data safe. The only way to do that is to have at least one copy on another device.
geojay wrote:
If I introduce the new drive in addition to the two existing drives, wait for it to sync and then remove one of the original two, what will happen?
Adding a new 4 TB drive will give you an 8 TB volume using RAID-5. Removing any drive after that will result in an 8 TB volume that is degraded (not redundant). Also, the volume would still be non-redundant while the volume is resyncing.
Hot-swapping one of the drives is the best way.
BTW, What size is the new drive? What is the reason for replacing it?
Jan 15, 2020Guru - Experienced User
