GloveNInja217
Apr 12, 2017Aspirant
LUN Disconnection caused loss of data
Good afternoon everyone, Last weekend I removed everything from my NAS and transferred it to other PCs so I could factory reset the NAS. I reconfigured it and generated a LUN which I mounted ...
mdgm-ntgr
Apr 12, 2017NETGEAR Employee Retired
Assuming you're using NTFS you'd need to use tools designed for the NTFS filesystem.
So you don't have a backup?
With LUNs it's advisable to use a UPS to reduce the likelihood of an unsafe shutdown.
Regardless of whether you use LUNs or not or what device you use you should backup important data regularly. Don't store it on just the one device.
GloveNInja217
Apr 14, 2017Aspirant
Do you have any recommendations for tools I can use for NTFS file recovery? Have you ever experienced this type of an issue before with the data existing in this "Limbo" state? I'm at a point where I'm ready to cut my losses and refresh the NAS once more. I'm now 2TB short on my total space and no way to find/remove that data.
I have backups in place, but not for my media and I have a UPS, but that doesn't fix someone in your home unplugging your hardware.
- StephenBApr 14, 2017Guru - Experienced User
You could try this: http://www.easeus.com/datarecoverywizard/free-data-recovery-software.htm
I've never used it, but other easeus tools have worked ok for me.
- GloveNInja217Apr 14, 2017Aspirant
I will definitely give that tool a try.
Do you know if I've configured my LUN wrong based on the problem? When the computer is power cycled the LUN shouldn't just disconnect right? Before I refreshed my NAS and upgraded the OS, I would reboot my PC and when I turned it back on I would see the LUN connected still as a M: in the computer.
Any ideas as to why that isn't happening now?
Also, I just power cycled my PC again. I lost the LUN, reattached it, and now I'm getting an error about the recycle bin being corrupted. Thoughts?
- mdgm-ntgrApr 14, 2017NETGEAR Employee Retired
Which version of ReadyNAS OS are you running?
Do you have a static I.P. set on the NAS?
