GloveNInja217
Apr 12, 2017Aspirant
LUN Disconnection caused loss of data
Good afternoon everyone, Last weekend I removed everything from my NAS and transferred it to other PCs so I could factory reset the NAS. I reconfigured it and generated a LUN which I mounted ...
GloveNInja217
Apr 14, 2017Aspirant
Do you have any recommendations for tools I can use for NTFS file recovery? Have you ever experienced this type of an issue before with the data existing in this "Limbo" state? I'm at a point where I'm ready to cut my losses and refresh the NAS once more. I'm now 2TB short on my total space and no way to find/remove that data.
I have backups in place, but not for my media and I have a UPS, but that doesn't fix someone in your home unplugging your hardware.
Apr 14, 2017Guru - Experienced User
You could try this: http://www.easeus.com/datarecoverywizard/free-data-recovery-software.htm
I've never used it, but other easeus tools have worked ok for me.
- GloveNInja217Apr 14, 2017Aspirant
I will definitely give that tool a try.
Do you know if I've configured my LUN wrong based on the problem? When the computer is power cycled the LUN shouldn't just disconnect right? Before I refreshed my NAS and upgraded the OS, I would reboot my PC and when I turned it back on I would see the LUN connected still as a M: in the computer.
Any ideas as to why that isn't happening now?
Also, I just power cycled my PC again. I lost the LUN, reattached it, and now I'm getting an error about the recycle bin being corrupted. Thoughts?
- mdgm-ntgrApr 14, 2017NETGEAR Employee Retired
Which version of ReadyNAS OS are you running?
Do you have a static I.P. set on the NAS?
- GloveNInja217Apr 15, 2017Aspirant
I am running OS 6.6.1 on the ReadyNAS. I have assigned a static IP to one of the NICs on the device. I do not have enough ports to plug in the secondary NIC as well so that is not being used.
