uw_photographer
Apr 26, 2012Aspirant
Mac newbie help!
I have been using my two ReadyNAS drives on my windows network for several years. However, I have had a mac for a while now (2011 MBP now running Lion) whose itunes library I want to sync with the rea...
victorhortalive
Apr 29, 2012Aspirant
Don't think the Mac will have gone to sleep while CCC is running.
Seems to me that you may have a more fundamental issue with your Mac to do with network connections and folder permissions.
Have you tried some real simple tests between the Mac/PC and Mac/NAS ? i.e. just simple copy/paste and copy/paste/delete.
That way you will see if the links are sound, then see if you can get CCC to do something equally simple between Mac/PC and Mac/NAS.
If all that works, then it is a problem with the Mac iTunes folder itself, perhaps.
