redpola
Nov 02, 2015Aspirant
Mac OS X USB recovery drive?
So, I proudly announced to my friend how great my RN104 is. Literally as he watched it said "upgrade firmware?". I clicked yes. Foolish. Now it's hung on "booting". I look for a fix and discover ...
- Nov 03, 2015
Luckily it's pretty simple on the ARM based systems.
Grab the USB recovery tool from here.
Grab your firmware from here.
Use Disk Utility to format the USB drive.
1 partition, MS-DOS (FAT) format.
Make sure Master Boot Record is selected under Options.
Copy to the USB drive:
- The "initrd-recovery.gz" and "NTGR_USBBOOT_INFO.txt" files from the "Marvell" directory
- The "uImage-recovery" file from the "Marvell/RN104" directory.
- The firmware image.
When you're done the layout should look like so:
siigna@tatooine /Volumes/USBRECOVERY $ ls -al total 134048 drwxrwxrwx@ 1 siigna staff 4096 Nov 2 18:21 . drwxrwxrwt@ 8 root admin 272 Nov 2 18:21 .. -rwxrwxrwx 1 siigna staff 0 May 22 2013 NTGR_USBBOOT_INFO.txt -rwxrwxrwx 1 siigna staff 63391744 Oct 27 11:49 ReadyNASOS-6.4.0-arm.img -rwxrwxrwx 1 siigna staff 2048370 Nov 27 2014 initrd-recovery.gz -rwxrwxrwx 1 siigna staff 3161676 Apr 25 2000 uImage-recovery
siigna
Nov 03, 2015NETGEAR Employee Retired
- redpolaNov 03, 2015Aspirant
Thanks very much! I'm surprised this information isn't already in the knowledgebase.
- siignaNov 04, 2015NETGEAR Employee Retired
That's been fixed as well. :)
- redpolaNov 04, 2015Aspirant
Outstanding! I've employed many software engineers and it's always refreshing to find one with a clue. Nice one.
Addendum: For bonus points you need to integrate this knowledge into your tech support's resources- the response I got from them was "not possible" and "use a Windows machine". :)
