ludovit8
May 18, 2014Aspirant
Machine failure, dala lost, I need advice
Hi, I have old nas ready duo 2. It works fine for a year but today it is very bad day for me. Nas was too loud all the tiem, fan or what ever was so noisy as it is during start, but usually nas 1...
mdgm-ntgr
May 19, 2014NETGEAR Employee Retired
The partition table is typically on disk 1. So all else being equal data recovery from disk 1 is easier.
The disk that doesn't have the partition table on it may appear to be blank, but it isn't. It should be obvious which disk is the one with the partition table on it when you use your data recovery software.
