Mivock
Mar 25, 2017Aspirant
Management service is offline (RN102)
Hello, Since this morning, I have an issue with my ReadyNAS 102. I was about to update it to 6.6.1 (from 6.6.0), but the download failed. I decided to restart the NAS (it's always on) then try ag...
- Mar 27, 2017
Your /opt/sickrage directory is 2.5GB. I just moved that to the data volume and created a symlink.
Rebooted it to normal mode and it appears to have come up fine.
mdgm-ntgr
Mar 25, 2017NETGEAR Employee Retired
Can you boot to volume read-only mode (a boot menu option) and try downloading the logs again?
Welcome to the Community!
Mivock
Hello mdgm, and thank you for your answer.
Well, from what I've read online, I only have these boot options on my NAS : Normal, Factory Default, OS Reinstall, Tech Support, Skip Volume Check, Memory Test and Disk Test. I tried the "skip volume check" option as I read in other posts, but unfortunately it doesn't seem to do anything when I boot that way.
So is there another another boot menu option I am not aware of? If so, how can I boot that way?
Thank you!
- MivockMar 26, 2017Aspirant
Hello mdgm,
I sent you a PM, but in the meantime I also had an access on the logs in my administration page, as I told you. For some reason I still can't download it, but it says (in French) that the volume root uses 100% of its capacity. I read on another post here that it could be a log file being too big. So, should I try to erase all the logs directly from the administration page?
Thanks.
- mdgm-ntgrMar 26, 2017NETGEAR Employee Retired
No. Unless you already have SSH enabled proceed with what I suggested in my PM. I'll try and have a look at it after I get some sleep.
- mdgm-ntgrMar 27, 2017NETGEAR Employee Retired
Rebooted it to normal mode and it appears to have come up fine.- MivockMar 27, 2017Aspirant
Thank you so much for fixing it mdgm so quickly, and also for letting me know what the problem was. It's now fully functionnal.
Thanks again!
- Jun 11, 2022Retired_Member
