Mivock
Mar 25, 2017Aspirant
Management service is offline (RN102)
Hello, Since this morning, I have an issue with my ReadyNAS 102. I was about to update it to 6.6.1 (from 6.6.0), but the download failed. I decided to restart the NAS (it's always on) then try ag...
- Mar 27, 2017
Your /opt/sickrage directory is 2.5GB. I just moved that to the data volume and created a symlink.
Rebooted it to normal mode and it appears to have come up fine.
Mivock
Hello mdgm, and thank you for your answer.
Well, from what I've read online, I only have these boot options on my NAS : Normal, Factory Default, OS Reinstall, Tech Support, Skip Volume Check, Memory Test and Disk Test. I tried the "skip volume check" option as I read in other posts, but unfortunately it doesn't seem to do anything when I boot that way.
So is there another another boot menu option I am not aware of? If so, how can I boot that way?
Thank you!
Mivock
Mar 26, 2017Aspirant
Hello mdgm,
I sent you a PM, but in the meantime I also had an access on the logs in my administration page, as I told you. For some reason I still can't download it, but it says (in French) that the volume root uses 100% of its capacity. I read on another post here that it could be a log file being too big. So, should I try to erase all the logs directly from the administration page?
Thanks.
- mdgm-ntgrMar 26, 2017NETGEAR Employee Retired
No. Unless you already have SSH enabled proceed with what I suggested in my PM. I'll try and have a look at it after I get some sleep.
- mdgm-ntgrMar 27, 2017NETGEAR Employee Retired
Rebooted it to normal mode and it appears to have come up fine.- MivockMar 27, 2017Aspirant
Thank you so much for fixing it mdgm so quickly, and also for letting me know what the problem was. It's now fully functionnal.
Thanks again!
- inxs92Mar 30, 2017Aspirant
HI MDM,
I am having a similar problem:
Please see the attached ogs.
I had a power failure , but when it came back. The above message occured,
Unable to launch the admin page.
How can I access admin page.
- mdgm-ntgrMar 30, 2017NETGEAR Employee Retired
Can you go to https://ip.address.of.nas/fwbroker and try updating to 6.6.1?
- Jun 11, 2022Retired_Member
