Mivock
Mar 25, 2017Aspirant
Management service is offline (RN102)
Hello, Since this morning, I have an issue with my ReadyNAS 102. I was about to update it to 6.6.1 (from 6.6.0), but the download failed. I decided to restart the NAS (it's always on) then try ag...
- Mar 27, 2017
Your /opt/sickrage directory is 2.5GB. I just moved that to the data volume and created a symlink.
Rebooted it to normal mode and it appears to have come up fine.
Mivock
Mar 26, 2017Aspirant
Hello mdgm,
I sent you a PM, but in the meantime I also had an access on the logs in my administration page, as I told you. For some reason I still can't download it, but it says (in French) that the volume root uses 100% of its capacity. I read on another post here that it could be a log file being too big. So, should I try to erase all the logs directly from the administration page?
Thanks.
mdgm-ntgr
Mar 27, 2017NETGEAR Employee Retired
- MivockMar 27, 2017Aspirant
Thank you so much for fixing it mdgm so quickly, and also for letting me know what the problem was. It's now fully functionnal.
Thanks again!
- inxs92Mar 30, 2017Aspirant
HI MDM,
I am having a similar problem:
Please see the attached ogs.
I had a power failure , but when it came back. The above message occured,
Unable to launch the admin page.
How can I access admin page.
- mdgm-ntgrMar 30, 2017NETGEAR Employee Retired
Can you go to https://ip.address.of.nas/fwbroker and try updating to 6.6.1?
Doing it right now..
I will let you know soon.
hopefully that should not erase any of my data
Thanks for your prompt response.
Sri
- Jun 11, 2022Retired_Member
