icuit
Feb 25, 2016Aspirant
Management service is offline
Hi. We have a problem whereby we can't access the Admin page, just says ReadyNAS Admin Page is offline. Within Raidar the status is "Management Service is offline". No firmware update has been app...
- Feb 26, 2016
No, it's not meant to be empty but that doesn't matter too much as i want to set the NAS up again from scratch. No i don't have a backup of the data but i don't need a backup.
Thanks
icuit
I'm not sure if this helps but i have found this in the logs:
Feb 25 15:13:55 *********** readynasd[4501]: readynasd log started
Feb 25 15:13:55 *********** readynasd[4501]: readynasd started. (restarted=0)
Feb 25 15:14:15 *********** readynasd[4501]: Error create table (db)
Feb 25 15:14:15 *********** readynasd[4501]: dba create failed
Feb 25 15:15:35 *********** readynasd[4501]: Error create table (db)
Feb 25 15:15:35 *********** readynasd[4501]: dba create failed
Feb 25 15:15:35 *********** readynasd[4501]: Initialization failed. We don't want to keep retrying. Only twice.
Thanks
mdgm-ntgr
Feb 25, 2016NETGEAR Employee Retired
I assume you downloaded the logs zip file using RAIDar?
You should have that zip file ready to provide to support. You can send your logs in if you like (see the Sending Logs link in my sig)
- Jun 10, 2022Retired_Member
