Hoygen83
Oct 30, 2015Aspirant
Management Service Is Offline
Hello everyone, I have a readynas2120 v2with firmware 6.2.4 For what seems a lack of power the nas has performed a forced shutdown yesterday. If i use raidar i can see Management Service Is Offlin...
JSiau
Dec 03, 2015Aspirant
I have a similar problem. I am running 6.4.0 on an RN2120. The managment service turns off and stays off for 24 to 36 hours. When it comes back on it only seems to work for a short period of time. I tried to upgrade to 6.4.1 but it doesn't seem to reboot after the download.
JennC
Dec 04, 2015NETGEAR Employee Retired
Hello JSiau,
Welcome to the community!
Please also check if the access to the shares is stable or intermittent too.
I checked your profile and found just a ReadyNAS 2100 registered. Can you please check again which model you are using and having trouble with? Some users of ReadyNAS 2100 also load OS6 to their OS4 NAS.
- JSiauDec 09, 2015Aspirant
I have a 2100, a 2120, and a 2120 R2. It is the older (non-R2) 2120 that is having problems.
- Jun 10, 2022Retired_Member
