Intelli32
Apr 11, 2013Aspirant
Map network drive with IP address
I have set up a DynDNS address "xyz.dlinkddns.com" and I can access my NAS via a web browser and now I want to set up a mapped drive. Using Windows i went into the map drive and entered "\\xyz.dlin...
Apr 11, 2013Guru - Experienced User
It is port related (port is 445) More importantly, many (perhaps most) ISPs block that port, so even if you forward it you are likely to have problems.
I suggest FTP or FTPS to access your files remotely (FileZilla is a good client).
