Intelli32
Apr 11, 2013Aspirant
Map network drive with IP address
I have set up a DynDNS address "xyz.dlinkddns.com" and I can access my NAS via a web browser and now I want to set up a mapped drive. Using Windows i went into the map drive and entered "\\xyz.dlin...
Intelli32
Apr 12, 2013Aspirant
StephenB wrote: It is port related (port is 445) More importantly, many (perhaps most) ISPs block that port, so even if you forward it you are likely to have problems.
I suggest FTP or FTPS to access your files remotely (FileZilla is a good client).
I get a error message 550 Permission Denied when I am trying to create files in my website directory. I am logging in via FTP on port 21 and the website folder FTP settings in the NAS is Read/Write, still no luck.
FTP-SSL does not work to connect with. Do I have to use SFTP to create files?
