Intelli32
Apr 11, 2013Aspirant
Map network drive with IP address
I have set up a DynDNS address "xyz.dlinkddns.com" and I can access my NAS via a web browser and now I want to set up a mapped drive. Using Windows i went into the map drive and entered "\\xyz.dlin...
Apr 12, 2013Guru - Experienced User
SFTP does not work the the NAS, however FTPS will. It does require that the client use "explicit TLS", not implicit.
You can upload files to NAS via FTP. Set the default FTP access for the share to "read/write" in frontview, and set the FTP authentication mode to "user" in services.
