Giulio
Jul 04, 2011Aspirant
mapped network drive disconnecting
Hi, I'm using a new readynas ultra 4 with 4x1tb HDD, i have some problem with mapped drive on windows. I create a public share and works correctly, under windows XP I map the share and works ok, b...
ewok
Jul 05, 2011NETGEAR Expert
Can you change your program to move a file every minute and see if that has any effect?
