Sulu
Jul 16, 2011Aspirant
Mapping A Share Fails to Connect At Startup
I am using Windows 7 I access my ReadyNAS Duo via Frontview I created one user: user1 and one group: users I have one share: files The share has been set with the following permissions: CIFS...
PandaMarketer
Jul 17, 2011Aspirant
Hmm.
The option to connect using different credentials is because by default, it will connect with your Windows logon details. So yes, you should do that when you first set up a mapped drive. The way I do it is to check both of those boxes before even browsing for the folder I want to map. Once I enter my Nas Admin creds (I use absolute paths ie: \\192.168.1.x\home\<user>\folder1) it immediately opens this new resource/drive in a new window. (I guess to confirm that's what I wanted)
I have no problems with reconnecting at logon.
Have you tried the command line batch (manual) reconnect at logon approach? (found in the wiki under "shares")
