Sulu
Jul 16, 2011Aspirant
Mapping A Share Fails to Connect At Startup
I am using Windows 7 I access my ReadyNAS Duo via Frontview I created one user: user1 and one group: users I have one share: files The share has been set with the following permissions: CIFS...
Sulu
Jul 20, 2011Aspirant
My attempt at mapping the drive (using the same methodology as the attempt that worked) failed to reconnect at startup so it doesn't fix the mapping issue. So I will go back to UNC and use that. The only downside that I can tell is the 11 or so seconds it takes to "connect" and start playing a music file with itunes. Once connected it seems speedy enough though. I am not sure why it would take so long to pass credentials and connect. I just built this PC using the latest components including an SSD drive so everything happens almost instantly except for this.
I am still disappointed after all my work to setup my PC and the NAS drive correctly that the final problem that brought the whole thing to a halt was not being able to map a network share... Come on Microsoft!
Thanks sphardy!
Thanks sphardy!
