Sulu
Jul 16, 2011Aspirant
Mapping A Share Fails to Connect At Startup
I am using Windows 7 I access my ReadyNAS Duo via Frontview I created one user: user1 and one group: users I have one share: files The share has been set with the following permissions: CIFS...
ewok
Jul 22, 2011NETGEAR Expert
The share folder owner and group don't really have anything to do with connecting to the share since they are filesystem level settings.
If guest access is enabled, then any unsuccessful authentication attempt will result in guest access. So UNC in Explorer works but clicking on the NAS in Network does not? Do you have any protocols other than CIFS enabled for the share?
