scravatt
Mar 24, 2016Apprentice
Maximum Harddisk Capacity
I currently have 6 Western Digital 6Tb drives in my 516NAS....at 36TB now (18GB usuable with RAID 10).. WD has a new 8TB HDD. Does the NAS support this extra size/capacity..i.e. 6x8TB=48TB (24GB wi...
mdgm-ntgr
Mar 28, 2016NETGEAR Employee Retired
That article has old information about the supported disk capacities.
The highest capacity disks on the Hard Disk Compatibility List are 8TB disks at this time. The ST8000NE0001 and HUH728080ALE604. Some 8TB disks don't fit in the drive trays and/or are not suitable for RAID use.
As for what the maximum disk capacity that will work that remains to be seen. As higher disk capacities become available there can be software fixes needed to provide the best support for the disks, which we would provide in firmware updates for current products. However it is possible that there may be hardware limitations that may be run into.
If you use a disk outside the compatibility list then support may refuse to help if you run into issues.
- StephenBMar 29, 2016Guru - Experienced User
The HCL still seems to lag. The ST8000VN002 and the WD80EFZX are both NAS purposed drives.
- scravattMay 20, 2016Apprentice
WD80EFZX is the same physical size as the WD60EFZX (which is on the list) ...just 8TB instead of 6TB. I bet it will work fine. I'll give it a shot....
- StephenBMay 21, 2016Guru - Experienced User
I have two installed (both running jbod) and they are working well. One is in an RN102, the other in an RN202.
Despite the ZX, the WD80EFZX are listed by WD as Red Drives. Temps are good (at the moment I see 33C for the WD80EFZX and 32C for the WD60EFRX in the same chassis).
The side mount holes are in the usual position, so the new toolless disktrays work with no problem. One pair of the bottom mount holes has moved though.
FWIW - With drives this size, the RAID sync times are ridiculously long on the RN100 series. Not an issue for your RN516, but a consideration for people using entry-level NAS.
- Sep 02, 2016Retired_Member
