michelefaccini
Oct 16, 2011Aspirant
mcrypt,<br /> error
Hi,I have just change my config.inc.php from $cfg['Servers'][$i]['auth_type'] = 'config'; to $cfg['Servers'][$i]['auth_type'] = 'cookie'; to enable a multi users session for phpMyadmin I get n...
michelefaccini
Under usr/bin mcrypt is present....trying to do sudo apt-get install php5-mcrypt phpadmin , I have an 'unmet dependencies' so I aborted to do something (I tried first with a sudo apt-get purge php5-mcrypt phpmyadmin but got an 'Invalid operation purge').
Readynasxtras suggested me to reinstall the add-on.....but doing so..I will loose all my php,sql settings,is it right ?
