FelixLee
Nov 02, 2018Aspirant
Migrate RN314 to RN626X
Hello,
Finally I purchased a new NAS RN626X, now I would like to migrate my existing RN314 4x2T to new NAS.
Firstly, the RN626X has confirmed the firmware is up-to-date in 6.9.4 Hotfix1.
Se...
- Nov 05, 2018
Hi FelixLee
Both RN314 and RN626X are OS 6 x86 Units so migrating the volume to your new NAS should have no problem.
Please see Migrating a volume
You will have to power both NAS and remove the disks from RN314, insert them in order to the RN626X. Settings will be with the RN626X once you have booted it.
Your users should be able to connect to your new NAS using the old IP used by RN314. Of course you need to make sure it is not being used so the RN314 should be disconnected on the Network.
Hope this helps!
Regards
Marc_V
Nov 05, 2018NETGEAR Employee Retired
Hi FelixLee
Hope this helps!
Regards
