MartinRN
Apr 22, 2022Tutor
Migrate Ultra 2 Plus volume to Ultra 2
I'm planning to upgrade a fully working ReadyNAS Ultra 2 Plus to OS 6 (unsupported of course). As a first step (obviously after backing up) I'd like to move the entire X-RAID2 volume to a recently ac...
- Apr 22, 2022
1) It should work. The one caveat to that is SSH. Note that if you have never installed EnableRootSSH on the Ultra 2, you'll need to install that before SSH will work on RAIDiator-x86 4.2.31. If EnableRootSSH has already been installed on that unit at some point and SSH is enabled on the disks then SSH should work straight away when you move the disks across.
2) It's best to move all disks across. Power down, remove disks (label order). The Ultra 2 must have no disks in it when you move the disks across and be powered down. You may wish to recalibrate the fan under Status > Health.
The Ultra 2 has a slower CPU, which is the main difference between it and the Ultra 2 Plus.
MartinRN
Apr 23, 2022Tutor
The migration to the Ultra 2 worked perfectly. I was a bit hesitant some parts of the config (e.g. network settings) would not be transferred, but it turned out it was essentially a chassis exchange. Turned all clients off, powered down the nas, moved the volume, powered up the Ultra 2, turn clients on again. Only a few minutes downtime.
mdgm Thanks for the tip on the root ssh access.
StephenBThanks for the tip on memory upgrade. I understand that 2GB is max for Ultra 2 Plus as there's only a single slot.
As I'd like to use the original disk set in the resulting OS 6 system the next step would be to pull out Disk 2 from the migrated volume and instantly replace with an empty disk to restore redundancy. How will the system handle this best, from a live system or turned off?
Sandshark
Apr 24, 2022Sensei
2GB is not the max on an Ultra2. Ignore whatever the specs say -- they are based on the largest drives available at the time of release and a very old version of the OS. Having only a single-core CPU, there may be a practical limit before it's operation is too sluggish, but you should be able to use drives up to the largest currently available. Switching to OS6 won't make any real difference in this area with a 2-bay unit, but still offers you a lot of improvements if you intend to continue using the NAS as a primary device.
