MartinRN
Apr 22, 2022Tutor
Migrate Ultra 2 Plus volume to Ultra 2
I'm planning to upgrade a fully working ReadyNAS Ultra 2 Plus to OS 6 (unsupported of course). As a first step (obviously after backing up) I'd like to move the entire X-RAID2 volume to a recently ac...
- Apr 22, 2022
1) It should work. The one caveat to that is SSH. Note that if you have never installed EnableRootSSH on the Ultra 2, you'll need to install that before SSH will work on RAIDiator-x86 4.2.31. If EnableRootSSH has already been installed on that unit at some point and SSH is enabled on the disks then SSH should work straight away when you move the disks across.
2) It's best to move all disks across. Power down, remove disks (label order). The Ultra 2 must have no disks in it when you move the disks across and be powered down. You may wish to recalibrate the fan under Status > Health.
The Ultra 2 has a slower CPU, which is the main difference between it and the Ultra 2 Plus.
Sandshark
Apr 24, 2022Sensei
2GB is not the max on an Ultra2. Ignore whatever the specs say -- they are based on the largest drives available at the time of release and a very old version of the OS. Having only a single-core CPU, there may be a practical limit before it's operation is too sluggish, but you should be able to use drives up to the largest currently available. Switching to OS6 won't make any real difference in this area with a 2-bay unit, but still offers you a lot of improvements if you intend to continue using the NAS as a primary device.
Apr 24, 2022Guru - Experienced User
MartinRN was talking about the max RAM he could put into the Ultra 2 Plus - not the max disk size.
- SandsharkApr 25, 2022Sensei
Yeah, duh! Misread GB as TB.
While the specs for the processor seem to indicate that's the max because the unit has but one RAM slot, the same is true of the Pro2 (same except architecture a dual-core processor) and some have found 4GB works in it. But 2GB should really be sufficient and the right kind of 4GB stick is rather expensive.
- MartinRNMay 09, 2022Tutor
Thanks for all the advice. The new system is up and running a few weeks now with on OS6 6.10.7 and 2GB of RAM. Works like a charm. Nice new interface, more up-to-date packages and snapshot support. Hope this little fellow will last a few more years...
