Alpacaman
Apr 11, 2026Tutor
Migrating Disks from NV+ to NVX
Hello Folks, I'm new here ... I have / had an old NV+ NAS with four 1TB drives. I hadn't used it for years and when I got it going again the other day, all was well for a few hours, backing up my...
Sandshark
Apr 11, 2026Sensei
The power supply from the NVX can be moved to the NV+ if you are sure it's just the supply that's at fault. But if something else took the supply out, you could end up killing the NVX supply.
Alpacaman
Apr 12, 2026Tutor
I'm pretty sure the PSU failed on its own ... we have a very stable 230V AC supply here in Somerset, UK. Perhaps a filtered outlet would provide a smoother waveform though.
- AlpacamanApr 13, 2026Tutor
Although [lightbulb moment] the PSU might have failed due to a failure of a component in the NV+ circuitry ... in which case the NVX PSU would then be at risk if I fitted it. I'll see if the NV+ PSU is repairable first.
