tommy747's avatar
tommy747
RN214 to RN626 Migration - Disk Placement
Hi,
I am planning a migration of my RN214 to a new RN626X, and was planning to;
- Update firmware on new RN626X using scratch disk.
- Power off RN214 and remove all disks in order (slot1=8TB, slot2=8TB, slot3=14TB, slot4=14TB)
- Place disks in RN626X in same order.
- Power on RN626X
My question is this;
Is there any benefit in moving the larger 14TB drive to slots 1&2 and move the 8TB's to 3&4, and rebuild from scratch?  I would prefer to do the simple move, but thought I would ask everyone's advice before doing it.
Thanks
  • Marc_V wrote:
    I don't think there is any benefit by switching out the drives even if you rebuild from scratch.
    I agree.
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    tommy747
    I don't think there is any benefit by switching out the drives even if you rebuild from scratch. Replacing the 8TB drives on slot 1 and 2 in the future is still possible and adding new drives as well.
    The steps you will be doing would be the advised steps as well.
    HTH
    • StephenB's avatar
      I agree.
      • Sandshark's avatar
        Sandshark
        Sensei
        If you originally started with drives smaller than 8TB, rebuilding would eliminate one or more "layers" of your RAID.  That has minimal effect.  The size order of the drives does not matter at all to the OS.  If you have some running hotter than others, putting them on the top or bottom or next to an empty bay will probably reduce their temperature, possibly slightly lengthening their life.
        I agree, not worth the effort.
ProSupport for Business
