oneoneseven
Apr 30, 2019Follower
Migrating from RN102 to RN214
Greetings,
I'm in a bit of a pickle here and I need some guidance on migrating over from an old ReadyNAS to a new one. I have an older RN102 unit, and the lifespan of the drives (RAID1) are com...
May 01, 2019Guru - Experienced User
oneoneseven wrote:
Do I have to manually recreate all the shares, permissions & users and push all the data to the new NAS myself? Or is there something I'm missing that will make my life easier?
As JohnCM_S says, you can simply power down the RN102, move the disks to the new NAS and power it up.
Or you could back up the configuration settings (system->settings->configuration backup). Make sure any apps you have running on the RN102 are installed on the RN214 before you restore the settings on the RN214. Also, some settings aren't migrated, so you should still spot-check the settings.
Though personally I just re-do the configuration from scratch myself.
