mas99
Jun 04, 2013Aspirant
Migrating NV Disks after PSU failure
Have a ReadyNAS NV for a number of years that had a PSU failure (hot, funky smell and rebooting) and the unit was covered under the service bulletin. I had expected Netgear to send me a PSU to s...
mas99
Jun 06, 2013Aspirant
I put in an old used disk to update the firmware. Firmware was 4.1.6 and I updated it to 4.1.10. When it rebooted, it shows the disk healthy, host name is still the old host name and it sends me warnings it can't find my listed shares (the original shares). Since they aren't on the disk that seems to make sense. It also says the volume is empty, though the disk in there is a 400GB disk. Does this all makes sense too?
If all this seems right, all I should do then is power down, insert my original 3 disks and start it up. It will then update the disks to 4.1.10 and I should be good to go?
The old shares should all be there and accessible. Does that sound right?
Just being careful. I have a lot of data on these disks.
