gsuttor
Jun 09, 2011Aspirant
Minecraft Linux on ReadyNas Pro Pioneer
Is it possible to run the Linux version of Minecraft server on the ReadyNas Pro Pioneer? Has anyone attempted it? If so please share. I'd love to run the box as a small home server for this. (2-3 p...
mdgm-ntgr
Jun 09, 2011NETGEAR Employee Retired
I don't know if it'll work, but you could give it a try.
First note that tech support does not support this, so you should proceed with caution.
I would suggest you:
1. Backup all the data on your NAS
2. Upgrade to the latest RAIDiator firmware (http://www.readynas.com/RAIDiator_x86_4_2_17_Notes) if you haven't already
3. If you haven't already install the EnableRootSSH add-on for x86: http://www.readynas.com/?p=4203. Installation is via Add-Ons > Add New
4. Install the Java community add-on: http://www.readynas.com/forum/viewtopic.php?f=48&t=45751
5. Login to SSH, user is 'root' and password will initially be set to your admin password. Use the Terminal on a Linux or Mac Machine or PuTTy on a Windows machine.
6. Download and attempt to install your minecraft server.
7. If you can get this working you'll want to setup a way to automate running this on startup, but best to see if it'll work first.
