gsuttor
Jun 09, 2011Aspirant
Minecraft Linux on ReadyNas Pro Pioneer
Is it possible to run the Linux version of Minecraft server on the ReadyNas Pro Pioneer? Has anyone attempted it? If so please share. I'd love to run the box as a small home server for this. (2-3 p...
gsuttor
Jun 24, 2011Aspirant
Works a treat... sometimes I even amaze myself ;)
UPDATE:
Now I'm noticing a side effect.
The unit will not shutdown with the three button press method (left it for half hour or so), It just holds onthat "SHUTTING DOWN" text o the LCD.
So I go into Frontview and choose shutdown & turn off, which it does.
On boot up it does a "Checking C:" phase every time I boot up. (which takes about an hour).
Second time it's happened now, would the running minecraft server somehow hold up shutdown of the ReadyNas (ie: can't close the server on shutdown) and cause the filesystem check on reboot?
Better take a good look at the email report. (edit: Pasted in next post)
Any advice appreciated.
UPDATE:
